ana1pac
#1 Posted : Tuesday, September 29, 2015 6:14:42 PM(UTC)
ana1pac
I have an Amana dryer that's stuck on delicate cycle setting. I can not change delicate cycle setting to anything else. It does heat up and work. Anybody know what it could be?
#2 Posted : Wednesday, September 30, 2015 1:58:01 AM(UTC)
Parts for NED7300W - AppliancePartsPros.com
Try unplugging it for a while to see if it will reset itself.
If this does nothing and the select button still pushes in out correctly then it is probably a bad control board.
Can't change dryer cycle setting (Dryer Repair)
by ana1pac 9/29/2015 5:33:22 PM(UTC)
