I have an Amana dryer that's stuck on delicate cycle setting. I can not change delicate cycle setting to anything else. It does heat up and work. Anybody know what it could be?
Here are your parts Parts for NED7300W - AppliancePartsPros.comTry unplugging it for a while to see if it will reset itself. If this does nothing and the select button still pushes in out correctly then it is probably a bad control board. |
THIS FORUM IS DEAD!!!!!!! |
