WesinMO
#1 Posted : Monday, September 28, 2015 1:25:26 PM(UTC)
WesinMO
Ok last weekend, my dryer stopped midcycle, heat and timer still working, but no spin. I unplugged it and took the front panel off, belt still on, so googling the problem, it said the thermal fuse on the blower is probably bad. So I bought the new thermal fuse, installed it, and it worked. My wife was doing laundry while i was at work, and it went bad again. Same symptoms, and I want to know what could be causing it to blow, before I go and spend more money on another fuse, which I know I have to anyway, but want to know if there is something else to get.
#2 Posted : Monday, September 28, 2015 1:37:05 PM(UTC)
The most common cause is a dirty vent system.
Check/clean it.
Also make sure the outside vent louvers are opening.
Thermal Fuse blowing up. (Dishwasher Repair)
by wojo.the.fixer 11/17/2012 6:18:55 PM(UTC)
Thermal fuse blowing (Dryer Repair)
by M.C. 2/8/2010 6:43:50 PM(UTC)
