My GE washer model WCXH208H1WW will tumble but not spin. I used a test i found in another link on this forum and with my limited diagnostic skills and an analog meter.... i think its the timer. My timer is a 131802100H. I see most timers listed as 131802100 ... with no trailing letter, or with a G or F. Does the letter suffix identify a specific version of the timer.. or ????? I've got a line on a used $25 replacement... but its a different letter suffix... will it work?? or blow up my control board.:eek:
first post... rookie member.. so please bear with me if I'm not doing this right.
Update on my DIY fix. It appears that the machine number is a Canadian model number and is throwing my parts search off. I got crossed over to a WSXH208H1WW on another site, and I've had better success with matching things up.
Long story short. I bought another broken Kenmore washer with a noisy pump problem. Since the motor control boards were the same, I did a successful timer and front panel transplant. Who knew that many of these parts were interchangeable between differently branded machines that are actually the same under the panel.
