hotrod325w
#1 Posted : Wednesday, September 9, 2015 4:49:04 AM(UTC)
hotrod325w
Installed LA-1053 thermostat kit to fix a no run condition. Runs great but front of dryer below lint trap get extremely HOT. Cleaned excessive lint from inside front panel during replacement. Scared to run it.......Help
CletusT
#2 Posted : Sunday, September 13, 2015 9:34:41 AM(UTC)
CletusT
I would check the housing where the blower assembly fits onto the machine. Sometimes this housing gets so full of lint that it only has a small space for air to exhaust.
The issue of it being too hot is most likely what caused the failure to begin with. There should also be a high limit cut off, depending on the model number.
#3 Posted : Monday, September 14, 2015 3:36:00 AM(UTC)
Did you clean/check your vent system?
This should not cause a heat build up here but it definitely will not help things either.
Whirlpool WED49STBW0 too hot (Dryer Repair)
by blackirish01@yahoo.com 10/11/2022 5:11:49 PM(UTC)
GE freezer section too hot on defrost (Refrigerator & Freezer Repair)
by CoolGuy247 12/21/2021 6:53:43 AM(UTC)
Low heat setting too hot on admiral dryer (Dishwasher Repair)
by Guest 11/20/2021 8:15:15 AM(UTC)
How hot is too hot? GE Monogram Fridge compressor is hot (Refrigerator & Freezer Repair)
by bzt8fs 8/10/2021 4:18:20 PM(UTC)
Whirlpool GS6NBEXRB01 Freezer too hot during defrost cycle (Refrigerator & Freezer Repair)
by Bill65 7/17/2020 10:57:10 AM(UTC)
Hotpoint Burner Gets Too Hot (Oven Repair (including Ranges and Cooktops))
by Rene.Rose 2/22/2020 5:17:12 AM(UTC)
Replaced Blower Motor, Dryer Air Now Seems Too Hot (Dryer Repair)
by sherrea 11/22/2019 8:02:54 AM(UTC)
frame between doors getting way too hot (Refrigerator & Freezer Repair)
by gwlyles214 4/5/2019 3:36:36 PM(UTC)
Dishwasher Running Too Hot (Dishwasher Repair)
by zboow 1/20/2019 6:25:32 AM(UTC)
Oven gets too hot, it's not the temperature sensor (Oven Repair (including Ranges and Cooktops))
by joymsburton 2/9/2018 4:30:36 PM(UTC)
Dryer too hot flips the thermal fuse (Dryer Repair)
by Maverick1 12/6/2017 6:29:07 AM(UTC)
Whirlpool oven temp too hot (Oven Repair (including Ranges and Cooktops))
by edorrian10 10/4/2017 1:18:52 PM(UTC)
Gas Dryer seems to get too hot. (Dryer Repair)
by Robert McGinity 12/18/2016 10:39:09 AM(UTC)
Frigidaire Stove Burner Gets too hot, replaced infinity switch (Oven Repair (including Ranges and Cooktops))
by questionforyouguys 7/11/2016 1:37:01 PM(UTC)
Condenser too hot and freezer is too warm (Refrigerator & Freezer Repair)
by lillady1225 6/22/2016 7:40:48 PM(UTC)
