I turned the washer on, cold water setting, and the water barely trickled out into the machine. I switched to hot water and it came out great, switched back and just a slow trickle. I checked both on/off valves and they were on. Ran two loads day before and it worked great. What do I check for?
check the water vale inlet screen by taking the water hose off the cold side to see if its stopped if not then your water vale is possibly bad.
