mostrander6@yahoo.com
#1 Posted: : Friday, August 28, 2015 5:53:33 AM(UTC)
I turned the washer on, cold water setting, and the water barely trickled out into the machine. I switched to hot water and it came out great, switched back and just a slow trickle. I checked both on/off valves and they were on. Ran two loads day before and it worked great.
What do I check for?
allen9258
#2 Posted : Saturday, August 29, 2015 2:10:49 PM(UTC)
allen9258
check the water vale inlet screen by taking the water hose off the cold side to see if its stopped if not then your water vale is possibly bad.
