ewade1601
#1 Posted : Monday, August 24, 2015 7:52:53 AM(UTC)
ewade1601
seems to get off balance a lot, when I watch it spin it gets up to speed and seems to disengage then starts spinning again and repeats this. clothes very wet at completion. having trouble with dryer too, wife getting impatient!
please help.
sidfink43
#2 Posted : Tuesday, August 25, 2015 6:45:51 AM(UTC)
sidfink43
Operate it with the front panel off and see if you can determine if something is awry with the support structure or springs. And you will be able to tell if the spinning is just slow or it stops. Also check out to make sure nothing is stuck in the pump or hoses coming from the machine.
If the problem is lack of spin you can try replacing this part.
Part number: AP4009132
But it sounds like a new basic pair might be in your future.
KENMORE 80 series wet clothes after spin cycle (Washer Repair)
by APPLIANCEDUDE1972 4/22/2015 4:05:46 PM(UTC)
Wet Clothes After Spin (Washer Repair)
by ZipAgent 4/21/2014 1:04:34 PM(UTC)
Maytag Atlantis wet clothes after spin (Washer Repair)
by Dkinyon 4/8/2013 10:05:33 AM(UTC)
by doitmayself 8/15/2011 11:31:09 AM(UTC)
Replaced clutch (fixed wet clothes after spin) makes a noise when it starts spin??? (Washer Repair)
by mikeal21 2/28/2010 12:29:53 PM(UTC)
by djmarti 3/12/2009 6:31:50 PM(UTC)
Wet Clothes after spin (Washer Repair)
by Bob V. 6/26/2008 6:56:03 PM(UTC)
