Any suggestions appreciated. Kenmore dryer - won't heat. Timer good Circuit board good Heating Element good Fuses good Motor good
Will turn on, run cold for one minute, then shut off. After shutting off, will run while on/off switch depressed, but shuts off when you let up on switch.
Thanks, davepool
Groups: Expert
This is an EvenHeat model, notorious for bad control boards. How do you know the board is good?
Eric
Hi Eric, I bought it new, so I can't say for sure that it is good. Thanks, David
