Took off the water control valve and didn't tag wires... long story it was going in garbage until I found the dishwasher was recalled. I had the recall for the control panel repaired and decided to replace the water valve and the drain hose. There are 3 wires: Purple, Green with Yellow stripe and a White wire. Water control valve has 3 male spades, one reads 110/120v the other 60hz and the other im assuming is a ground. Which wire go where?
Also want to replace the drain hose as it is brittle at the bend into the kitchen base cabinet. Do I remove the base or the side to get to the start of the drain hose? Thanks in advance... George in Cleveland
Can't locate wiring diagram anywhere. Called Bosch and they will not provide me one unless I'm a tech. Suggested I call for service. OK $100 for a service call and repair to plug a wire in. Any help greatly appreciated!
George
