iflooru
#1 Posted : Wednesday, October 28, 2009 2:31:36 PM(UTC)
iflooru
Took off the water control valve and didn't tag wires... long story it was going in garbage until I found the dishwasher was recalled. I had the recall for the control panel repaired and decided to replace the water valve and the drain hose. There are 3 wires: Purple, Green with Yellow stripe and a White wire. Water control valve has 3 male spades, one reads 110/120v the other 60hz and the other im assuming is a ground. Which wire go where?
Also want to replace the drain hose as it is brittle at the bend into the kitchen base cabinet. Do I remove the base or the side to get to the start of the drain hose? Thanks in advance... George in Cleveland
iflooru
#2 Posted : Thursday, October 29, 2009 9:42:50 AM(UTC)
iflooru
Can't locate wiring diagram anywhere. Called Bosch and they will not provide me one unless I'm a tech. Suggested I call for service. OK $100 for a service call and repair to plug a wire in. Any help greatly appreciated!
George
