kaharvey
#1 Posted : 10 years ago
kaharvey
it leaks at bottom of door.I don't see a gasket
Simon / APP Team
#2 Posted : 10 years ago
Simon / APP Team
Groups: APP Team
Hi.
If you have a small leak it may come from the soap dispenser gasket. If you will remove the outer door you will be able to see this leak. If it leaks more substantially it could be the faulty door gasket or the crack in the lower wash arm may cause water to spray directly onto the inner door, causing the leak.
Here are the breakdown diagrams and parts list for your dishwasher:
Model DWU7402AAE
The door gasket Part number: AP4111635
The lower wash arm Part number: AP4112900
The grommet seal Part number: AP4113007
Good luck. Please keep us posted with the results.
Thank you,
Simon.
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 10 years ago
Frigidaire Gallery Washer Leaks at Bottom (Washer Repair)
by calvin83 11 years ago
hotpoint washer leaks at bottom (Washer Repair)
by amberhalsey 13 years ago
Maytag Washer leaks at bottom (Washer Repair)
by ronf 14 years ago
Refrigerator Leaks at bottom of freezer (Refrigerator & Freezer Repair)
by usha shah 16 years ago
by rbennett 16 years ago
