it leaks at bottom of door.I don't see a gasket
Rank:: Advanced Member
Groups: APP Team
Hi. If you have a small leak it may come from the soap dispenser gasket. If you will remove the outer door you will be able to see this leak. If it leaks more substantially it could be the faulty door gasket or the crack in the lower wash arm may cause water to spray directly onto the inner door, causing the leak. Here are the breakdown diagrams and parts list for your dishwasher: Model DWU7402AAE
The door gasket Part number: AP4111635
