tekram
#1 Posted : Wednesday, August 5, 2015 4:42:25 PM(UTC)
tekram
I have a broken hinge on my washer. It is actually a rental property and I am trying to figure out if this kind of damage can be done with normal wear and tear. I have included pictures if that helps. It is not the main hinge but a smaller hinge that helps guide the door closed.
Thanks.
tekram attached the following image(s):
tekram
#2 Posted : Thursday, August 6, 2015 7:19:00 AM(UTC)
tekram
Is this the part I need to replace this?
http://www.********************...er/8563964/0026/110.html
