I have a broken hinge on my washer. It is actually a rental property and I am trying to figure out if this kind of damage can be done with normal wear and tear. I have included pictures if that helps. It is not the main hinge but a smaller hinge that helps guide the door closed. Thanks. tekram attached the following image(s):
