My son drilled a hole in the bottom of the plastic tub, he thought the washer was broken so he was going to drain the water.Well it wasn't broken and it works so I was wondering if there is any thing to plug the holes so it doesn't leak, or do I have to get a new a whole
You can try to seal it but most likely it will need a new tub.
