batech
#1 Posted : Wednesday, July 22, 2015 12:34:14 PM(UTC)
batech
We just relocated our existing French door fridge into the garage, about 3 weeks ago. Now lost all cooling! Has power, fans are running, compressor not running and warm to the touch. Did continuity test on pins to compressor, appears to be fine. Not sure if start relay or capacitor are the issue.
#2 Posted : Thursday, July 23, 2015 1:27:23 AM(UTC)
Parts for Amana AFF2534FEW Refrigerator - AppliancePartsPros.com
See the attachment for your tech sheet.
The overload can be checked with a meter to see if there is continuity.
There is not a good way to check the start device or capacitor so you will have to try a new one.
Did you also check the windings to the compressor to make sure a winding is not grounded?
That the compressor is warm but not vibrating is a bad symptom as it indicates that the compressor does have power to it.
One thing to not is that a winding check can tell you that a compressor is bad but does not tell you that the compressor is good as it may have other internal problems.
batech
#3 Posted : Saturday, July 25, 2015 9:07:11 AM(UTC)
batech
Thanks denman. I replaced the start device/overload, and the compressor still does not run. So, I think it will need a new compressor. I have tried to read the windings with a meter, and I think there is a short between the two lower pins.
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
