Not sure what to do now. I was getting a F31 message so I ordered the control board. Got it all hooked up and then gave it a try. I set the clock and then hit the oven button....beep error F30. So what part would go with this error code?
Thanks, Jackie
THIS FORUM IS DEAD!!!!!!! |
Are these oven sensors also for gas ovens? When I went to the link it was showing electric range information.
Jackie
Groups: APP Team
Hi. You probably should check if the oven sensor is connected properly to the control board. Here is your oven sensor Part number: AP4433173
Thank you, Simon.
