jsm81041
#1 Posted : Thursday, July 9, 2015 7:08:18 PM(UTC)
jsm81041
Not sure what to do now. I was getting a F31 message so I ordered the control board. Got it all hooked up and then gave it a try. I set the clock and then hit the oven button....beep error F30. So what part would go with this error code?
Thanks, Jackie
#2 Posted : Friday, July 10, 2015 3:31:57 AM(UTC)
F30 is an open oven sensor.
I am not sure what is going on because F31 is a shorted oven sensor.
Below is info on the sensor.
Take a look at 7, 8, 20 and 21.
http://www.applianceaid.com/ele...-range-repair-topics.php
jsm81041
#3 Posted : Friday, July 10, 2015 9:54:28 AM(UTC)
jsm81041
Are these oven sensors also for gas ovens? When I went to the link it was showing electric range information.
Jackie
Simon / APP Team
#4 Posted : Friday, July 10, 2015 4:03:55 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You probably should check if the oven sensor is connected properly to the control board.
Here is your oven sensor Part number: AP4433173
Thank you,
Simon.
