Ajohns28
#1 Posted : Tuesday, July 7, 2015 7:40:10 PM(UTC)
Ajohns28
Tonight with no warning, the water on my fridge started dispensing and would not stop. I could only make it stop by shutting off the water valve. I suspect the water actuator or something in the power board has failed. Any suggestions?
Simon / APP Team
#2 Posted : Wednesday, July 8, 2015 11:30:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the power connectors from the water inlet valve and open the water. In case if water still comes through the dispenser, replace the water inlet valve
Part number: AP5671757
Thank you,
Simon.
