Tonight with no warning, the water on my fridge started dispensing and would not stop. I could only make it stop by shutting off the water valve. I suspect the water actuator or something in the power board has failed. Any suggestions?
Groups: APP Team
Hi. Remove the power connectors from the water inlet valve and open the water. In case if water still comes through the dispenser, replace the water inlet valve Part number: AP5671757
Thank you, Simon.
