KITCHEN AID wall over error code F6 EO. What would produce this code?
Here are your parts Parts for KitchenAid KEMS378SWH04 Oven - AppliancePartsPros.comFollowing is a link to a tech sheet for this unit Download KEMS378.pdfUncheck the Use our download manager option and then use the grey button to download it. Otherwise the site may put software onto your computer that you do not want. I do not recommend messing with a microwave unit unless you have experience working with electronics/high voltage. Have you tried removing power to the unit for a few minutes to see if it will reset itself? |
THIS FORUM IS DEAD!!!!!!! |
