Faymond
#1 Posted : 10 years ago
Faymond
KITCHEN AID wall over error code F6 EO. What would produce this code?
#2 Posted : 10 years ago
Parts for KitchenAid KEMS378SWH04 Oven - AppliancePartsPros.com
Following is a link to a tech sheet for this unit
Download KEMS378.pdf
Uncheck the Use our download manager option and then use the grey button to download it.
Otherwise the site may put software onto your computer that you do not want.
I do not recommend messing with a microwave unit unless you have experience working with electronics/high voltage.
Have you tried removing power to the unit for a few minutes to see if it will reset itself?
