Ice maker is functional but not dispensing ice through the door. Bin on inside of freezer door stays full. Can not locate service/repair manual online. I'm guessing the auger motor is the culprit. My dilemma is I need instruction on dismantling the freezer door to r & r the motor. Anyone? :confused:
Groups: APP Team
Hi. If the ice door opens when the pad is pressed and the ice chute is not frozen then most likely there is a problem with the auger motor Part number: AP3181486
Click on the picture to get the repair video. Good luck. Please keep us posted with the results. Thank you, Simon.
