so my wonderful Bosch dishwasher has started acting up after all theses years...stainless inside and out.....the buttons are on the front top right...no buttons can be pressed...its stuck on rinse/hold and i can't press any other buttons...so it will run for about 10 minutes on that cycle only... what could be the problem I cant run a test because I cant push any buttons other than the rinse hold and thats pretty much stuck too
I have tried unplugging; pushing all the buttons etc etc
parts needed etc??? any help or links please..
Open the control panel and inspect the tabs on the control module front cover. If they are broken then most likely a new cover would solve the problem. - The control module front cover Part number: AP2802872
I thought I had replied to this back in October thanks Gene I ordered the part you told me too and fixed it in about an hour with taking of the door etc etc.. thanks alot! works like a charm now
You are welcome. Good luck with your dishwasher.
