domisell
#1 Posted : Tuesday, October 27, 2009 6:02:37 PM(UTC)
domisell
so my wonderful Bosch dishwasher has started acting up after all theses years...stainless inside and out.....the buttons are on the front top right...no buttons can be pressed...its stuck on rinse/hold and i can't press any other buttons...so it will run for about 10 minutes on that cycle only...
what could be the problem
I cant run a test because I cant push any buttons other than the rinse hold and thats pretty much stuck too
I have tried unplugging; pushing all the buttons etc etc
parts needed etc???
any help or links please..
#2 Posted : Wednesday, October 28, 2009 3:48:17 PM(UTC)
Open the control panel and inspect the tabs on the control module front cover. If they are broken then most likely a new cover would solve the problem.
- The control module front cover Part number: AP2802872
domisell
#3 Posted : Tuesday, May 18, 2010 12:20:26 PM(UTC)
domisell
I thought I had replied to this back in October
thanks Gene I ordered the part you told me too and fixed it in about an hour with taking of the door etc etc..
thanks alot! works like a charm now
#4 Posted : Tuesday, May 18, 2010 1:29:05 PM(UTC)
You are welcome. Good luck with your dishwasher.
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Bosch dishwasher troubleshooting (Dishwasher Repair)
by Dan T in SD 12/7/2023 2:38:23 PM(UTC)
Bosch Dishwasher intermittently leaking on lower right of door (Dishwasher Repair)
by jjtrinva 11/5/2023 9:30:06 AM(UTC)
Bosch Dishwasher Model SHE3AR56UC/07 (Dishwasher Repair)
by EDK1747 8/30/2023 7:42:58 AM(UTC)
Bosch Dishwasher SHE3AR56UC/07 (Dishwasher Repair)
by Guest 8/27/2023 11:27:21 AM(UTC)
Bosch Dishwasher skips to "clean" even after part replacement (Dishwasher Repair)
by Guest 6/20/2023 5:17:19 PM(UTC)
Bosch dishwasher SHX65T55UC/07 not dispensing soap unless in "Express" mode (Dishwasher Repair)
by callussun 4/19/2023 9:46:00 PM(UTC)
Bosch dishwasher shem3ay 55n/25 (Dishwasher Repair)
by Guest 3/23/2023 5:18:20 AM(UTC)
Bosch dishwasher only drains on reset and specific cycle (Dishwasher Repair)
by vusedad 10/18/2022 8:54:46 AM(UTC)
Bosch dishwasher model SMV41D10EU/48 Not working (Dishwasher Repair)
by adriandlb 10/7/2022 12:18:47 AM(UTC)
Bosch Dishwasher SHX68T55UC/02 Leak Identified: How to Fix? (Dishwasher Repair)
by jonneytaee 8/31/2022 4:48:51 AM(UTC)
Bosch Dishwasher Model SHPM65Z56N (Dishwasher Repair)
by Guest 7/8/2022 9:00:03 AM(UTC)
