ken@kdalla.com
#1 Posted : Sunday, June 7, 2015 6:54:18 AM(UTC)
ken@kdalla.com
Timer will not turn and heat comes on intermittingly.
Have replaced Timer switch, Cycling thermostat and Thermal fuse.
Is there anything else that can be causing my problem?
fairbank56
#2 Posted : Sunday, June 7, 2015 7:09:25 AM(UTC)
fairbank56
Groups: Expert
Probably faulty gas valve coils. Timer won't advance in auto dry unless heat is cycling normally.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Eric
ken@kdalla.com
#3 Posted : Thursday, June 11, 2015 9:00:08 AM(UTC)
ken@kdalla.com
Eric:
Thank u for your suggestion. Have order replacement coils. I will let u know if that solves my problem
Kenny D
Dryer Timer Will Not Turn (Dryer Repair)
by danmanv2 10/17/2016 9:57:50 AM(UTC)
timer will not turn off (Dryer Repair)
by lancevancourt 10/15/2009 4:34:30 PM(UTC)
Timer will not turn off (Dryer Repair)
by rb8941 8/1/2007 6:30:00 AM(UTC)
