Timer will not turn and heat comes on intermittingly.
Have replaced Timer switch, Cycling thermostat and Thermal fuse. Is there anything else that can be causing my problem?
Groups: Expert
Eric: Thank u for your suggestion. Have order replacement coils. I will let u know if that solves my problem
Kenny D
