tcockerhambuilds@cox.net
#1 Posted : Friday, May 29, 2015 2:47:01 PM(UTC)
Two things occurred prior to oven not working. First the use of self cleaning mode, second 3 power surges in an hour. Power checks out all the way to power board. However no display or noise.
#2 Posted : Saturday, May 30, 2015 3:59:50 AM(UTC)
I cannot find any tech info on the given model number.
Please check it.
Have you tried removing power from the unit for a couple minutes to see if it will reset?
Does sound like the control board is blown.
#3 Posted : Saturday, May 30, 2015 4:16:06 AM(UTC)
Looks like I may have figured this out.
Some idiot at Whirlpool decided to use the number 0 and the letter O in model numbers.
So the first 0 should be a o
Model number is wos51ec0ab01
Here are your parts.
Parts for Whirlpool WOS51EC0AB01 / Oven - AppliancePartsPros.com
Have you checke4d the thermal fuse (item 7 in section 04).
This would kill power to the control board.
File Attachment(s):
WOS51.pdf (2,025kb) downloaded 4 time(s).
Viking gas broiler and oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 12/4/2023 2:39:31 PM(UTC)
Dacor oven, upper oven not working (Oven Repair (including Ranges and Cooktops))
by notyepcars 11/26/2022 8:40:21 AM(UTC)
oven not working, gives me a code F3 (Oven Repair (including Ranges and Cooktops))
by cj9113 10/16/2021 7:56:35 AM(UTC)
GE PROFILE PGB995DET1WW Top oven not working (Oven Repair (including Ranges and Cooktops))
by Guest 9/6/2021 9:36:45 AM(UTC)
Whirlpool microwave/oven not working (Oven Repair (including Ranges and Cooktops))
by naik71 9/3/2020 5:51:16 PM(UTC)
Thermador oven not working DP366CS/03 (Oven Repair (including Ranges and Cooktops))
by Chanmomu 6/30/2020 5:07:14 AM(UTC)
whirlpool WOD93EC0AS double oven bottom oven not working (Oven Repair (including Ranges and Cooktops))
by Chemsal 3/18/2020 3:28:11 AM(UTC)
KDRP467KSS08 / KDRP467KSS0 KitchenAid oven not working (Oven Repair (including Ranges and Cooktops))
by larrywick 10/18/2019 2:28:40 PM(UTC)
Oven On light stays lit - Oven not working properly (Oven Repair (including Ranges and Cooktops))
by Lometir 3/20/2019 7:54:34 AM(UTC)
ge oven not working (Oven Repair (including Ranges and Cooktops))
by mcp1212 9/25/2018 1:00:51 PM(UTC)
maytag range oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by tpwd 3/27/2018 3:28:20 PM(UTC)
Whirlpool Accubake Oven Not Working (Oven Repair (including Ranges and Cooktops))
by buddha61 11/15/2017 5:18:32 PM(UTC)
Maytag oven not working (Oven Repair (including Ranges and Cooktops))
by dtmeyer 10/14/2017 12:48:25 PM(UTC)
Oven not working after self cleaning (Oven Repair (including Ranges and Cooktops))
by Nalk 1/20/2017 7:05:57 PM(UTC)
stove oven not working but burnerws do (Oven Repair (including Ranges and Cooktops))
by jnevill1 1/1/2017 7:20:12 AM(UTC)
