Two things occurred prior to oven not working. First the use of self cleaning mode, second 3 power surges in an hour. Power checks out all the way to power board. However no display or noise.
I cannot find any tech info on the given model number. Please check it.
Have you tried removing power from the unit for a couple minutes to see if it will reset?
Does sound like the control board is blown. |
THIS FORUM IS DEAD!!!!!!! |
Looks like I may have figured this out. Some idiot at Whirlpool decided to use the number 0 and the letter O in model numbers. So the first 0 should be a o Model number is wos51ec0ab01 Here are your parts. Parts for Whirlpool WOS51EC0AB01 / Oven - AppliancePartsPros.comSee the attachment for the tech sheet. Have you checke4d the thermal fuse (item 7 in section 04). This would kill power to the control board. |
