frankie1961
#1 Posted : Monday, May 25, 2015 10:27:49 AM(UTC)
frankie1961
My refrigerator is not cooling compressor comes on then after about 5-10 sec it shuts off. It will do this around every 10-15 mins.
Thanks for ur help
#2 Posted : Tuesday, May 26, 2015 3:30:25 AM(UTC)
Parts for Whirlpool ED5LHAXMQ10 Refrigerator - AppliancePartsPros.com
Sounds like the compressor is overheating.
Is the condenser /compressor fan running?
It should be.
Check the compressor windings, see the below link.
Check them for resistance and that they are not grounded.
There is not a good way to check the start device so if the compressor checks out OK then you have to just buy one and try it.
Note that the compressor checks using a meter can tell you if a compressor is bad.
It does not tell you that a compressor is good as it may have internal mechanical problems.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
File Attachment(s):
ED5LH.pdf (696kb) downloaded 3 time(s).
