My refrigerator is not cooling compressor comes on then after about 5-10 sec it shuts off. It will do this around every 10-15 mins.
Thanks for ur help
Here are your parts Parts for Whirlpool ED5LHAXMQ10 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. Sounds like the compressor is overheating. Is the condenser /compressor fan running? It should be. Check the compressor windings, see the below link. Check them for resistance and that they are not grounded. There is not a good way to check the start device so if the compressor checks out OK then you have to just buy one and try it. Note that the compressor checks using a meter can tell you if a compressor is bad. It does not tell you that a compressor is good as it may have internal mechanical problems. How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com |
THIS FORUM IS DEAD!!!!!!! |
