Need help diagnosing problem: Oven won't light. When I press start, I hear 2 clicks but it doesn't light. I do not smell gas. I believe the oven is a spark ignite. I took off the flame spreader and do not see any spark when the clicks happened. Any help will be appreciated. Thank you
I did a search of the related models and I seem to fall into the "two clicks no gas" category which indicates the gas safety valve. Does that make sense? How do I access the gas safety valve on this stove model? Is it on the back? I have a multimeter I can use to test.
Thanks, this is the best repair blog I have seen yet.
