gizmodyne
#1 Posted : Sunday, April 26, 2015 6:36:01 AM(UTC)
gizmodyne
Need help diagnosing problem:
Oven won't light.
When I press start, I hear 2 clicks but it doesn't light.
I do not smell gas.
I believe the oven is a spark ignite.
I took off the flame spreader and do not see any spark when the clicks happened.
Any help will be appreciated.
Thank you
gizmodyne
#2 Posted : Sunday, April 26, 2015 6:48:46 AM(UTC)
gizmodyne
I did a search of the related models and I seem to fall into the "two clicks no gas" category which indicates the gas safety valve. Does that make sense?
How do I access the gas safety valve on this stove model? Is it on the back?
I have a multimeter I can use to test.
Thanks, this is the best repair blog I have seen yet.
