fz5w1c
#1 Posted : Friday, April 24, 2015 2:25:36 PM(UTC)
fz5w1c
My Whirlpool washer just started a loud knocking noise during the agitation/washing cycle. All other cycles operate normally and with no loud knocking noises. Are there any ideas as to what I can look at to stop this noise? The washer is perfectly level and I just replaced the agitator dogs thinking that this might solve the issue, but it didn't.
fairbank56
#2 Posted : Friday, April 24, 2015 5:54:45 PM(UTC)
fairbank56
Groups: Expert
Post a video to youtube so we can hear it.
Eric
fz5w1c
#3 Posted : Saturday, April 25, 2015 4:39:24 AM(UTC)
fz5w1c
fairbank56
#4 Posted : Saturday, April 25, 2015 4:58:01 AM(UTC)
fairbank56
Groups: Expert
fz5w1c
#5 Posted : Saturday, April 25, 2015 12:10:35 PM(UTC)
fz5w1c
Thank You Eric!! I appreciate your help.
fz5w1c
#6 Posted : Sunday, April 26, 2015 4:52:00 AM(UTC)
fz5w1c
I have the transmission part on order and have a follow up question. I can remove the top part of the agitator no problem, but the bottom part stays in the machine. Do I need to remove the bottom part of the agitator to install the new transmission? If so, how do I remove the bottom part of the agitator?
fairbank56
#7 Posted : Sunday, April 26, 2015 5:02:22 AM(UTC)
fairbank56
Groups: Expert
Yes, it must be removed. So, you took the agitator bolt out and the top half came off? The bottom part just fits over the splines on the agitator shaft. You should be able to pull it off. May be a little stuck.
Eric
fz5w1c
#8 Posted : Sunday, April 26, 2015 5:12:55 AM(UTC)
fz5w1c
Yes, the top half comes off when the bolt is removed. I'll put a little extra effort in pulling the bottom part up out of the machine. Thanks!!
