My display went blank. When pushing the buttons, a beep is heard. When hitting the start, a series of beeps are heard. The same with the clean oven button. The oven lights can be turned off and on via the panel. From what I have read, it sounds like the control board is bad. I have removed the side trim from the ovens but can't figure out how to take the control head off. How do I get at the control board?
Thanks.
Originally Posted by: oldsman207  My display went blank. When pushing the buttons, a beep is heard. When hitting the start, a series of beeps are heard. The same with the clean oven button. The oven lights can be turned off and on via the panel. From what I have read, it sounds like the control board is bad. I have removed the side trim from the ovens but can't figure out how to take the control head off. How do I get at the control board?
Thanks. I figured it out - the oven had to be slid out of the cabinet a couple of inches which exposed 2 screws on each side. Unfortunately I broke one of the front cover's plastic tabs figuring it out...
