JOETMCC68
#1 Posted : Monday, April 20, 2015 5:29:44 PM(UTC)
JOETMCC68
My bake element went out. In process of checking it I did what never supposed to do. Forgot to unplug power source. Sparked the end when I was pulling ends out. Now nothing works . Control panel , burners , oven. Need some possible things to check . What is causing the problem. Installed a new bake element already. The plug is getting power so it's not the breaker. Please help.
#2 Posted : Wednesday, April 22, 2015 3:12:18 AM(UTC)
Parts for Frigidaire FEF365BGWC Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316002662.pdf
Since the oven control panel and stove top burners use different parts of the supply voltage I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
