My husband dented our freezer door. I would like to see about replacing the stainless steel french door front for the lower freezer. I have been unable to locate a part number for this item.
Here are your parts. Parts for PFSS6PKX - AppliancePartsPros.comYou seem to be missing a few digits at the end of the model number so you will have to choose a unit from the Matching Model Numbers section. Looks like it is Item 189 in Section 01. I would say that this is the complete door but to confirm this it would be best to call a parts representative. They have more info and knowledge on parts than I do. On most newer units the insulation is foam so you cannot just buy the outside skin. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman Here are your parts. Parts for PFSS6PKX - AppliancePartsPros.comYou seem to be missing a few digits at the end of the model number so you will have to choose a unit from the Matching Model Numbers section. Looks like it is Item 189 in Section 01. I would say that this is the complete door but to confirm this it would be best to call a parts representative. They have more info and knowledge on parts than I do. On most newer units the insulation is foam so you cannot just buy the outside skin. Thank you I will check that out.
