Lotsofspots
#1 Posted : Saturday, April 18, 2015 11:32:25 AM(UTC)
Lotsofspots
My husband dented our freezer door. I would like to see about replacing the stainless steel french door front for the lower freezer. I have been unable to locate a part number for this item.
#2 Posted : Sunday, April 19, 2015 1:24:45 AM(UTC)
Here are your parts.
Parts for PFSS6PKX - AppliancePartsPros.com
You seem to be missing a few digits at the end of the model number so you will have to choose a unit from the Matching Model Numbers section.
Looks like it is Item 189 in Section 01.
I would say that this is the complete door but to confirm this it would be best to call a parts representative. They have more info and knowledge on parts than I do.
On most newer units the insulation is foam so you cannot just buy the outside skin.
Lotsofspots
#3 Posted : Sunday, April 19, 2015 8:36:20 AM(UTC)
Lotsofspots
Thank you I will check that out.
