wrench191
#1 Posted : Thursday, April 16, 2015 8:57:34 AM(UTC)
wrench191
Frigidaire Side by Side Refrigerator is not cooling properly. There is ice buildup at freezer wall.
I took it apart and big ice chunk at the top of freezer around suction tube. Not in fins. It was blocking fan flow.
The defrost element doesnt go that high to where the ice was. Is it low on freon?
#2 Posted : Friday, April 17, 2015 5:15:13 AM(UTC)
A model number would be helpful.
Find your model number - AppliancePartsPros.com
Defrost the unit manually to get rid of the ice buildup.
Then replace the rear cover. You should not have to screw it on.
Plug the unit in and let it run for about an hour.
Make sure that the compressor runs for the full hour. if you do the below check during or shortly after a defrost cycle you may end up with the wrong diagnosis.
Remove the cover and check the evaporator coils. If they have a fairly even coating of frost on them then the sealed system is probably OK.
If the ice ball is where the tubing enters the rear of the freezer make sure that the sealant/putty is OK.
If the coils are OK and the seal is OK I would check the door seals.
Check that they are clean.
Take a 2 inch wide strip of paper, place it between the seal and the unit's frame and then shut the door and pull the paper out to check the seal.
Work your way around both doors every 8 inches or so.
Check the hing side of the seals to be sure they are not grabbing and twisting when the door closes. A light coating of vaseline or white lithium grease usually fixes this.
Note that another low freon symptom is that the compressor will run all the time except when the unit goes through a defrost cycle.
wrench191
#3 Posted : Friday, April 17, 2015 11:57:07 AM(UTC)
wrench191
Seal ok, and door seals ok. defrosted with heat gun. I checked low side press. 2-3lbs. I added some until 5lbs, compressor runs all the time unless defrosting.
So far seems a little better but not nearly enough. Compressor a little hot to the touch. I removed the back to expose freezer upper half frosted and somewhat frozen. Bottom half clean.
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 4/22/2024 8:17:01 AM(UTC)
kenmore/lg fridge not cooling (Refrigerator & Freezer Repair)
by rleescott 4/16/2024 4:52:09 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Mabe MBC12GAZASS Not Cooling (Refrigerator & Freezer Repair)
by MKDrepair 2/5/2024 5:57:08 AM(UTC)
GE GSS23QSTA not cooling after power outage (Refrigerator & Freezer Repair)
by sfarid123 12/19/2023 7:39:47 AM(UTC)
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Ge Monogram Integrated Top/Bottom Not Cooling ZICP360NXLH (Refrigerator & Freezer Repair)
by grundyv2 10/7/2023 12:48:51 PM(UTC)
GE botom freezer not cooling (Refrigerator & Freezer Repair)
by Dieselista 10/6/2023 5:39:30 PM(UTC)
Whirlpool WRV986FDEM00 is not cooling (Refrigerator & Freezer Repair)
by Find a fix 9/23/2023 4:03:34 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
Samsung family hub freezer not cooling (Refrigerator & Freezer Repair)
by foster1447 8/20/2023 2:36:12 PM(UTC)
Whirlpool Refrigerator cooling intermittently or not cooling at all (Refrigerator & Freezer Repair)
by lsitnj 8/12/2023 3:39:26 PM(UTC)
Freezer is not cooling, fan is not working, light not on, NEW control board; GE fridge GSS25GSHJCSS (Refrigerator & Freezer Repair)
by Guest 8/6/2023 3:06:23 PM(UTC)
Refrigerator working, freezer not cooling (Refrigerator & Freezer Repair)
by Guest 7/11/2023 6:24:54 AM(UTC)
Kenmore Coldspot Model 106 not cooling (Refrigerator & Freezer Repair)
by wdeagle 7/2/2023 8:54:15 AM(UTC)
