jam325
#1 Posted : Monday, April 13, 2015 7:17:37 PM(UTC)
jam325
I am trying to figure out if I can replace the cycling thermostat heater with a newer part.
This is what is currently broken on my dryer
http://www.********************...;ss=a8b6d157607&mr=1
I want to know if I can replace it with this
http://www.amazon.com/3387134-3...+Thermostat+Heater+61894
The second part looks to b newer and is a single unit where the current unit is in two pieces. From what I can tell the parts should be interchangeable but I am no expert.
Thanks!
jam325
#2 Posted : Monday, April 13, 2015 7:28:06 PM(UTC)
jam325
sorry this part is what is broken.
Whirlpool 61894 Thermostat - AppliancePartsPros.com
for some reason that link did not work.
fairbank56
#3 Posted : Tuesday, April 14, 2015 7:51:01 AM(UTC)
fairbank56
Groups: Expert
We cannot recommend doing that. You are trying to use a part which was not designed to be used in your particular model dryer.
Eric
