You have been a member since:: 4/9/2015(UTC) Posts: 1
Hi, So glad to be here,any help appreciated. I just replaced the starter relay/overload 3 days ago,since the compressor would shut off after a few seconds.Compressor now works good, freezer gets near zero on 4. But the fridge will not get colder than 45. I had opened the freezer back panel and drain tube had no ice,fan would run when I plugged it in,and coils only had a little frost .Drain pan periodically has water in it,so seems defrost system is fine. Maybe an airflow problem? If that is true,I dont know what to do. Thanks fo any help. Ben oh....fridge is 13.5 years old, but compessor is only about 10,was repaced under warranty.Oh,and before the compressor starting problem,there was frost on MANY packages of foods in the freezer/
I was about to post myself, but this is very similar to the same issue I'm having so I'll follow this. My defrost system is working fine. Replaced the cold control and no change. I can't see an air return on my Kenmore and I'm thinking like you that maybe this is an airflow issue, but just can't see what could be wrong.
