stargazer4591
#1 Posted : Tuesday, April 7, 2015 7:42:35 AM(UTC)
stargazer4591
my WHIRLPOOL BRAVO WASHER HAS AN F1 CODE. THE WASHER WILL START BUT THE TUB IS NOT MOVING.
Jeff / APP Team
#2 Posted : Wednesday, April 8, 2015 6:29:03 AM(UTC)
Jeff / APP Team
F then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched,
kinked, plugged, or leaking air?
➔ If F then 1 repeats numerous times after
POWER/CANCEL is pressed and the
pressure hose connection is not pinched
or kinked, replace the machine/motor control.
Part number: AP4454689
