my WHIRLPOOL BRAVO WASHER HAS AN F1 CODE. THE WASHER WILL START BUT THE TUB IS NOT MOVING.
F then 1 flashes when the control detects an out of range pressure signal. ➔ Check pressure hose connection from tub to machine/motor control. Is hose pinched, kinked, plugged, or leaking air? ➔ If F then 1 repeats numerous times after POWER/CANCEL is pressed and the pressure hose connection is not pinched or kinked, replace the machine/motor control. Part number: AP4454689
