Wasnt cooling at all so Replaced compressor relay and that got it running. Now temperatures in freezer is -20 and regular food compartment is 25degrees. Any ideas for repair?
Here are your parts Parts for KitchenAid KSRS27ILSS01 Refrigerator - AppliancePartsPros.comSee the attachment for the tech sheet. If the condenser/compressor fan is also staying on then you know it is a temperature control issue. When you diagnosed the original problem did you disconnect anything that could effect the temperature control? If yes go back and check that area. Run the diagnostics. |
THIS FORUM IS DEAD!!!!!!! |
Tried diagnostic test. Thermisters check ok.
Since the thermistors are OK then I would say that the control board is the problem. |
