Larry627
#1 Posted : Saturday, March 28, 2015 9:14:00 AM(UTC)
Larry627
Wasnt cooling at all so Replaced compressor relay and that got it running. Now temperatures in freezer is -20 and regular food compartment is 25degrees. Any ideas for repair?
#2 Posted : Sunday, March 29, 2015 2:05:46 AM(UTC)
Parts for KitchenAid KSRS27ILSS01 Refrigerator - AppliancePartsPros.com
If the condenser/compressor fan is also staying on then you know it is a temperature control issue.
When you diagnosed the original problem did you disconnect anything that could effect the temperature control?
If yes go back and check that area.
Run the diagnostics.
File Attachment(s):
KSRS27IL.pdf (637kb) downloaded 1 time(s).
Larry627
#3 Posted : Sunday, March 29, 2015 7:25:37 AM(UTC)
Larry627
Tried diagnostic test. Thermisters check ok.
#4 Posted : Monday, March 30, 2015 2:00:11 AM(UTC)
Since the thermistors are OK then I would say that the control board is the problem.
