Dryer stopped producing heat, so I tested all the sensor and the thermal fuse was blown, no continuity. So I replaced it with the pack that has the thermal fuse and thermostat. It worked for three loads, then it blew again. I cleaned all lint out, cleaned everything. Replaced fuse and it ran for three loads again and it blew. So I am at my wits end. Help.
I said thermal fuse when I meant thermal cut off 352 degree
