sowens004@woh.rr.com
#1 Posted : Sunday, March 8, 2015 6:44:46 PM(UTC)
Dryer stopped producing heat, so I tested all the sensor and the thermal fuse was blown, no continuity. So I replaced it with the pack that has the thermal fuse and thermostat. It worked for three loads, then it blew again. I cleaned all lint out, cleaned everything. Replaced fuse and it ran for three loads again and it blew. So I am at my wits end. Help.
#2 Posted : Sunday, March 8, 2015 7:01:28 PM(UTC)
I said thermal fuse when I meant thermal cut off 352 degree
