Also, dryer sheets tend to clog the lint filter. Clean with soap and water and dry. That also helped.
Originally Posted by: JDC33020  Also, dryer sheets tend to clog the lint filter. Clean with soap and water and dry. That also helped. Finally had enough and got rid of the Bosch. Got the LG top loading HE and very happy.:)
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Bosch WTMC5321 light does not work, bulb is ok
Originally Posted by: JDC33020  Ok, I had the same issues. THe repair man first reset the dryer, that did not work. He finally came back and replace the following parts. For free which leads me to believe this is a defect since my dryer is 5 years old and out of warranty. Parts # 154166 Sensor 436435 PC board 503642 Work Time422221 Sensor Machine is running perfect now. Like I said I think this has been a defect that they just are not doing a recall. Six months ago, I had the same problem, and the maintenance guy did the same thing. I believe you are right that this is a minor disadvantage. Edited by user Wednesday, May 19, 2021 8:56:30 AM(UTC)
| Reason: Not specified
