The LED seem to stuck at number 19, and Rinse Only option with the light blink. This indicate that the Rinse Aid is low. Try to hit Start/Cancel button, and also reset the circuit breaker, but I still can't select other option, such as "Normal Wash", "eco wash". None of these button work. Does low Rinse Aid cause the rest of the option not working? I don't need to use rinse aid, since my water is clean. Is there a manual reset option, since I already tried to reset the breaker, and hit Start/Cancel? Or is it the sign of bad control panel, that need to be replace? The only message is, "19", and it stuck at "Rinse Only" mode. Thanks a lot in advance, Laratta
